10-06-2025
10:32
10:54
MarioSFitbit
10-06-2025
10:32
10:54
MarioSFitbit
Moderator edit - updated subject for clarity
Best AnswerHello @Mtacy
I'm not sure why you're no longer seeing the steps that were there before.
I suspect there might be a syncing issue between your data on the Fitbit servers and the Fitbit app. Most likely, your step history was correctly updated on your account on the Fitbit servers since you did see the steps in the app.
For now, please submit this issue using the Feedback option in the Fitbit app:
The feedback reports are received by the team for review.
If I find any updates on this issue, I'll report back.
