02-22-2025
12:10
06:36
MarioSFitbit
02-22-2025
12:10
06:36
MarioSFitbit
I have a Charge 6 that shows it is on Version 210.26. The current version for Charge 6s is 214.24. When I do the steps to update (Today tab, selecting device) there should be a pink Update button to select, but there isn't an Update button. How do I update to version 214.24?
Moderator edit - updated subject for clarity
I have done everything listed on "how do I update the fitbit device" and app, but I can't see the firmware updated.
The new app also does not support the old Sp02 reading too.
Do I need to do the factory reset in order to see the opinion?
(I am in Australia)
Best AnswerNo, still no update available. It's really annoying. I understand that it's a progressive release but a snail would have released it faster than that. My guess is that it's a problematic update and they're trying to fix it. We are waiting for months now...
Best AnswerI'd just like to post that this morning, indeed the 214.24 update finally arrived here, in California.
So apparently it is just necessary to keep up hope....
Installation was straightforward.
Now, the Bluetooth update part.
And, the 'indicators'....
My conclusion is that the 'indicators' are mainly an inducement to get you to update the firmware, and that what they really want is that you do it so that the Bluetooth changes can get put in place.
Good to have the latest firmware, anyway, and the Charge 6 has been working very well, including the no-phone inbuilt GPS. The secret to that is following their advice about a loose fit -- what that does is let the watch ride on its sensor bump, not squashed down with the sides flush on your skin. And that lets the antenna for GPS function, as it's built near the bottom sides.
And in addition, the band is much more comfortable when allowed to be loose, so it doesn't particularly get stuck to the skin. Having tried it both ways, with one of those very flexible perforated sports bands Google offers that I got with the watch.
Just a quick update. Finally got the new update 214 in Canada today for my Charge 6.
Install was really quick took about 5 minutes, the reconnect to Bluetooth was done within 1 minute.
All seem to be good. Hopefully everyone else gets the update quickly now.
Also thanks for a lot of replies offering difficult ways to update or get the update button on the app.
Best AnswerHi @Jayes249 ,
If I've understood you correctly, it seems that the strikeout should be expected, and not an irritant.
It's telling you that there's no current Heart Rate measurement available.-- as you said, when your device is out of range.
So this way you won't try to read it and get a wrong answer, or believe what would be an incomplete and thus not up to date history.
Sound rigtht, seen this way? I did notice some refinements in how the latest app is presenting several items of its information, so it seems this one also was well intended. Unless it's getting in your way in another fashion!
Best on it,
Clive
Best Answer(Please note this problem applies to clock faces where the heart rate reading appears middle-top and when it happens to coincide with the bluetooth disconnected symbol.)
Not quite correct - the clock face is still showing what appears to be the
correct heart rate when disconnected, it's just that it only appears
briefly before the strike-through, which then remains on the screen until
it refreshes eg. after the next raise to wake. I find this annoying as I
often miss the reading on first glance and need to move my wrist (to
refresh the screen) to view it on second glance.
It will be interesting to see what the rest of the community thinks!
