01-04-2026
11:41
11:49
MaCrisGBFitbit
01-04-2026
11:41
11:49
MaCrisGBFitbit
Hello @Judy1204! Welcome to our community forums!
I'm sorry to hear that you are unable to pair your Charge 6 again. I appreciate all the steps you try before contacting.
Sometimes the device remains in the Bluetooth device list, so I suggest you check if it still appears and if so, please remove it:
After that try to pair the tracker again: How do I set up my Fitbit device?
If your Fitbit doesn't appear in the Bluetooth list please take a look to the following article: Why can't I set up my Fitbit device?
Hiya I've just gons through the same thing and finally reconnected mine. First I rebought the official fit bit charger. Id lost mine and had bought other cheaper versions. So I got the proper one again and did all the restart stuff with it.
Then I looked at my devices on the app. I had an odd pairing to a phone which was paired to another device. As soon asi disconnected that one my fitbit turned back on.
I don't honestly know why these sorted it (or even if they did) but they are worth a shot.
Hi, @Judy1204 , I would recommend letting the Fitbit battery die completely and then recharging it. Then I would suggest trying the re-set process again. If it continues to fail the best bet is to get in touch directly with Fitbit Customer Support on contact.fitbit.com . They will advise on the next steps.
Hi @Judy1204! Thank you for your response,
I'm glad to know that you finally paired your Charge 6.
I'd like to invite you to visit our Health & Wellness board where you can share your experiences, meet people and create new topics.
@Julia_G thank you so much for your support.
