11-19-2023
03:02
10:02
FatimaFitbit
11-19-2023
03:02
10:02
FatimaFitbit
Yesterday I tracked a run, GPS used phone, all good.
Today I track a walk, uses watch GPS, which then shuts off when watch reaches about 30% charge. GPS is set to dynamic, why does it do this? Same with the Charge 5, so not an issue spacific to the Charge 6.
Does anyone else have this issue? And why would GPS on watch shut off at 30% battery?
Please don't say the solution is to set GSP to phone, that's a hack, not a solution.
Best AnswerSince this impacts both Charge 5 and Charge 6, sounds like it's a software fix that's needed.
Also, probably needs a software fix for shutting off watch GPS at 30% battery, I would prefer to choose.
@DavidNS For me, the Charge 6 built-in GPS connects and then disconnects and never reconnects. So battery level has nothing to do with it. To be honest, I see a better solution to the problem (to be implemented in the future Charge trackers) - throw away useless GPS modules and free some space for the altimeter. Most likely, the current issue is that the GPS hardware is just not fit for the job (ie. too small antenna) and most likely, no software will fix it.
This isn't just about the GPS not always connecting, I hade full GPS tracking on my walk for about an hour and a half, then there was a message on screen - I didn't have my glasses on so couldn't read it both times it has happened. After this message, no more GPS tracking on the walk. So GPS shuts down when the tracker battery reaches a certain level, but there was no information on this.
@DavidNS the message you talking about is probably the one I have seen, too - that Charge 6 gives up trying to connect (I don't remember exact words used but saw it a few times). This happens when GPS disconnects at some point of activity and tracker tries to reconnect but it isn't successful so it eventually (I presume it's 10 minutes like other models) it stops trying to connect and from that moment there is no way to get GPS back. But that happened to me regardless the battery level.
