12-04-2023
14:35
13:05
AndreaFitbit
12-04-2023
14:35
13:05
AndreaFitbit
So I bought a Charge 6 upgrade from the 5 a few weeks ago and within a day I had lost the watch somewhere because the band just popped off. After a desperate search I decided to just buy another one and instant regret sunk in when within 20 minutes of wearing it the band just popped off when I brushed against my bed frame. Thankfully I noticed it and put it back on, but I've noticed over the past few weeks the band constantly just pops off with the slightest but of awkward pressure. I'm a mechanic, so I'm using my hands all day, and I've NEVER had this problem with any other fitbit over almost a decade. I'm constantly checking my wrist making sure it hasn't just decided to leap off... and it's becoming irritating. It makes me just not want to wear a fitbit anymore.
I'm gonna ask here if anyone (or if FITBIT themselves, god forbid) have a solution for this? Honestly if it pops off one more time I'm just gonna buy a different brand watch I hate having to be paranoid about it all day. I wasted $180 once because of this obvious design flaw and I feel like I should just consider the other $180 wasted because it's inevitably going to fall off somewhere I'll lose it again.
I've tried several different bands from different brands because the ones they send with it are trash. All of them pop off just as easy.
Moderator Edit: Clarified subject.
06-16-2025 10:50
06-16-2025 10:50
Yes, my kept falling off too and unfortunately I also lost it!
It's only 11 months old and I think the warranty should cover a faulty device, but customer care told me it is not their "policy" to replace lost items.
Which I find irritating given this is clearly an issue as identified by all the comments here...
Best Answer06-25-2025 12:30
06-25-2025 12:30
I had constant issues with my Charge 5, so I went back to a 4, which has a more secure clasp arrangement. I was looking here to see if there were issues, I guess there are so not going to upgrade to the 6 for sure now. I'll stick with my little refurbished 4.
Best Answer06-25-2025 12:40
06-25-2025 12:40
I had problems with my 4, the open button came off. Only on 1 side. But after a few years of using the other kind of band it broke on the other side too. I have the other kind on my new charge 6, and no issues at all.
Best Answer06-27-2025 01:26
06-27-2025 01:26
Just got a new charge 6 and was debating returning it thinking it was a flaw in that latch but found your comment and it worked so here to say thanks!
08-14-2025 11:27
08-14-2025 11:27
I just came here to say to try the same thing. This has worked for me-no idea why except that the connectors are slightly differently shaped so maybe that is the difference and why this works.
08-21-2025 20:12
08-21-2025 20:12
In the last few months Ive been having the same issue with my Charge 6. I've tried multiple bands and even wearing differently, (likes flipped), I've cleaned the lock area also. Still with the slightest twist of my wrist or bump it pops off. I too, was thinking about changing brands/style, just to have a different band. I don't want to, but like others have also said, this is very frustrating.
Best Answer08-22-2025 03:17
08-22-2025 03:17
I think you're either going to replace it preemptively, or you'll replace it when you lose it for good. I was "fortunate" enough to find it about eight times, and eventually I Lost it for good. Never again.
Best Answer09-09-2025 13:25 - edited 09-09-2025 13:58
Same thing is happening to me... I have a couple ideas that I am going to try... I think the issue may be the replacement metal bracelet band that I put on soon after I got the Fitbit 6... I'm not a fan of the original supplied rubber bands, and have been using similar metal bracelet types on my previous Charge 5 and 4 that eventually stopped working properly... so I'm re-installing the original band to see what happens... if I don't end up losing it !
09-13-2025 08:30
09-13-2025 08:30
I am not having a problem with the original rubber Fitbit Charge 6 band that I reinstalled after wearing it for several days... so I decided to see what the problem might be with the replacement metal bracelet band might be... it seem to work find for several days when I first received it, but I had it fall off a few times recently.
From what I could tell, the issue is that the groove behind the locking piece on the metal bracelet is not quite deep enough, so I deepened the groove a bit by relieving some metal using my Dremel tool and a pointed bit.
The band now locks in place, and I cannot pull it out by tugging on it... I have worn it for several days, so I decided to report my finding... here is a photo to help show what I did... this may be an issue with other replacement bands.
10-07-2025 11:53
10-07-2025 11:53
The same here. Original band popped of and I replaced it. Band popped off again and I lost it and don’t know when. Bought another Fitbit and it has popped off and I felt the release and put it up in fear of losing a second one. What is the purpose? How do I get support?
Best Answer10-07-2025 12:02
10-07-2025 12:02
Hello @Lfields930
You can use this link to contact Support (<-- click). Complete the prompt in Step 1. Tap Continue in Step 2 (ignore Resources) to get to Step 3, which has the contact options.
Best Answer10-24-2025 02:56
10-24-2025 02:56
Good idea!
Best Answer12-11-2025 13:25
12-11-2025 13:25
Ok. I upgraded from 5 to 6 as well. This is my 2nd charge 6, as the first one kept popping off band. They sent another one, however, no change. In fact this band/watch is worse. It barely stays on
Best Answer12-12-2025 22:13
12-12-2025 22:13
