04-24-2026
07:13
08:48
MariLuFitbit
04-24-2026
07:13
08:48
MariLuFitbit
The battery on my Fitbit charge6 has become unpredictable.
after a fully charge it shows 70% in few minutes and shuts down in an hour.
on recharging it gets to 100% in no time and after taking it off the charge again shows the same random charge and shuts down.
Already done the restart, factory reset but the same behaviour continues. This is around 18 months old device.
Hi @VGang, Welcome to our community forums!
I'm sorry to hear that your Charge 6 is running out of power faster than expected. I will do my best to help you with this.
Also, charge your Charge 6 to 100% and use it as you normally do until the battery runs out to check if the battery life has changed.
I recommend you to visit Can I extend my Fitbit device's battery life? for more tips and information.
MariLu | Community Moderator, Fitbit
Believe and act as if it were impossible to fail.
