08-28-2024
23:17
05:09
CrisVillaFitbit
08-28-2024
23:17
05:09
CrisVillaFitbit
Hi,
I left my charge 6 on the table before going to bed. The next morning I found that it's counting 20+ thousands steps by itself. This happens few times already. How to fix it?
Moderator edit: edited title to clarity.
Best Answer08-29-2024 05:17
08-29-2024 05:17
Hello @Lsw1604! Welcome to the Fitbit Community.
Thanks for letting me know about this situation in regards to your Charge 6 counting steps when not wearing it.
My best recommendation would be for you to restart the Charge 6. I'm positive this will help you.
Best Answer08-29-2024 08:17
08-29-2024 08:17
Hi, Thank you for your reply and advice. I did the restart when the problem first occurred. But it does not seem to fix the problem. Now I am trying to place it at different area to monitor if the issue goes away. Meanwhile, any other suggestion is much appreciated.
Best Answer09-11-2024 11:09
09-11-2024 11:09
There are 2 reasons people get lots of false steps.
09-13-2024 18:46
09-13-2024 18:46
Hi,
You are right that the false counting is probably due to vibration from the table fan. So far I do not have any issue after placing Charge 6 to different location. It is strange that it only happens to charge 6 but not charge 4 and versa that I put in the same location.
