Hello @Gordonx3
You should feel a vibration when the device is seated correctly on the charger. If you don't feel the vibration, it may be the cable or the device as you noted. If this is the case, you should contact Fitbit support (<-- click link) They may have troubleshooting steps to help determine which piece is defective.
