03-26-2024 14:52
03-26-2024 14:52
I have my new band for 2 weeks more or less, today during a walk I tried to sync my phone with the band and since then the band has been crazy. During the workout it showed HR 138 during 10min even when I stopped walking after that doesn't not turn on when I face the band, I touch multiple times in the screen and nothing happens, if I touch the side button it shows the fitbit symbol (think its restaring), sometimes shows crazy HR values, like 150 while sitting then it shows 80, then 130. Something odd is going on. It's a brand new band. Someone had same problem before?!
Thank you
Best Answer03-27-2024 04:04
03-27-2024 04:04
Welcome to the Fitbit community, @davidmatias!
Sad to hear your Charge 6 isn't working as expected.
As a first approach to hopefully get things fixed, I'd suggest restarting it. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Also you should verify that the charging contacts on your device are clean and the charging pins on it's charging adapter are clean as well and can move flawlessly. In doubt please have a look here:
How do I clean my Fitbit device?
Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 6 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'd like to point out that it sometimes requires more than one attempt to restart Charge 6. So, before throwing the towel, please give it another try.
If that really won't work for you, please try if changing your device's clock face will get it back to working order. Here's how to do that:
How do I change the clock face on my Fitbit device?
I'll keep my fingers crossed.
