04-08-2025 12:57
04-08-2025 12:57
Started using my charge six again recently. As far as i can remember i used to be able to go into my heart rate and there would be a graph where i could see my bpm at all times throughout the day. Now when i go in it says no data. But it is checking my heart rate cause it shows on the screen and my resting heart rate is there. Thanks
Best Answer04-08-2025 13:39
04-08-2025 13:39
Hello @Rock240191
You're talking about seeing your heart rate graph in the Fitbit app, correct?
If so, are you able to do a sync between your Charge 6 & the Fitbit app? If you're seeing your heart rate on your Charge 6, it should show in the app when you do a sync.
Best Answer04-08-2025 16:10
04-08-2025 16:10
Yes on the app, i have synced around 5 times in the last two days. Graph still says no data
04-09-2025 10:59
04-09-2025 10:59
Hello @Rock240191
Thank you for your reply.
Although I'm not sure that these will work, there are a couple of things that you could try.
Please let us know if any of this worked for you.
Best Answer04-11-2025 09:12
04-11-2025 09:12
Hi! I’ve had this issue with my inspire HR since the update to the HR graphs. Weirdly the only thing that fixed it was switching my phone to 24hr clock not 12hr clock (iPhone). Hope that can help 🙂
