03-14-2025 14:53
03-14-2025 14:53
The left hand corner is a little red dot. When I click on it, it says charge 6 no info, sync now. I sync it and nothing changes.
Best Answer03-15-2025 14:04
03-15-2025 14:04
Hello @Leannek18
If I understand correctly, you're seeing a red dot in the left hand corner of your Fitbit app. Is that right?
And, when you do a manual sync, you don't see any updates to your data in the Fitbit app?
If this is the case, this help page has the recommended troubleshooting to try: Why won't my Fitbit sync (<-- click link)
If you are still having problems after trying the recommended troubleshooting, you might try setting up your Charge 6 as a new device. Don't remove the Charge 6 from the app first. Click on Add more devices, select the Charge 6, & follow the prompts to set up your Charge 6.
Let us know if you were able to fix the problem.
Best Answer03-15-2025 14:48
03-15-2025 14:48
Best Answer03-20-2025 02:32
03-20-2025 02:32
No problem not fixed !!!!!
Best Answer03-20-2025 06:28
03-20-2025 06:28
This happened to me for a while as well, no amount of resetting did anything. And since yesterday the problem went away by itself.
Best Answer03-20-2025 07:44
03-20-2025 07:44
It's been happening since I got the 6 almost a year ago. Still happening currently as I had to turn it all off this morning.
