Charge 6 not holding a charge
My Charge 6 was fulling charged this morning at 8 am. Now 9 hours later my battery is at 2%. Please assist.
4 REPLIES 4
Welcome to the Fitbit community, @Libby56!
Sad to hear that you're having an issue with your Charge 6.
As a first approach to hopefully get things fixed, I'd suggest restarting it. Before doing so you should make sure you've synced your device to not lose any data tracked so far. Also you should verify that the charging contacts on your device are clean and the charging pins on it's charging adapter are clean as well and can move flawlessly. In doubt please have a look here:
How do I clean my Fitbit device?
Next please closely follow these instructions as timing is crucial for this procedure:
1.) Connect your Charge 6 to the charging cable which has to be connected to a reliable power source.
2.) Press the button located on the flat end of the charging cable 3 times within 8 seconds(!), holding each press for about 1 second(!).
3.) Wait around 10 seconds until the Fitbit logo appears on your device's display.
I'd like to point out that it sometimes requires more than one attempt to restart Charge 6. So, before throwing the towel, please give it another try.
If that really won't work for you, please try if changing your device's clock face will get it back to working order. Here's how to do that:
How do I change the clock face on my Fitbit device?
Finally, please have a look at 'What are tips to extend my Fitbit device's battery life?' following the link below to see what might have a negative impact on your device's battery runtime:
Can I extend my Fitbit device's battery life?
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2, Pixel 4a, Pixel 7
I feel your pain😠.
please share the outcome.
LX
I reset and recharged the device. So far it's OK, it's been about 18 hrs since I last charged it & I am at 91%
So far today it appears to be working properly. I did a reset and charged back to 100%. It has been 18 hrs. and is at 91% charge as of now.
