07-19-2024 02:38
07-19-2024 02:38
Best Answer07-20-2024 10:31 - edited 07-20-2024 10:37
Welcome to the forums @NoaMauda.
Thank you for sharing the inquiry regarding your Charge 6. Sorry to know the difficulty that you are experiencing.
Please, try to perform a restart as indicated in this help article: How do I restart my Fitbit device?
In addition, change the clock face: How do I change the clock face on my Fitbit device?
Confirm that your device is update: How do I update my Fitbit device?
Best Answer07-21-2024 10:26
07-21-2024 10:26
Best Answer07-21-2024 10:42
07-21-2024 10:42
Mine died July 18. Had 87% charge. Fitbit support insists that I clean my charger with rubbing alcohol because, it could be an issue with the charger. Really idiotic. Given the loss of the dashboard, and the trash quality of Google's ability to listen to customers, I am not entirely sure why I contacted Support, but let's see what comes of it.
07-22-2024 12:32
07-22-2024 12:32
Unfortunately, nothing helped
Best Answer07-22-2024 16:22
07-22-2024 16:22
I'm having the exact same issue. They have either a bad firmware version or some sort of design/manufacturing defect. Contact support, go through their steps and they should replace it with one (that hopefully) works. I've noticed that after it crashes, leaving it plugged in for 5 to 10 minutes can be necessary before the 1, 2, 3 button press reboots it. Sometimes you need to press very methodically to get it to restart. 1, 2, 3, release. 1, 2, 3, release. Going too fast or to slow won't work.
