I have a not even 3 month old charge 6. (iPhone 13pro)
now the watch doesn’t respond. I tried all the reset options but nothing helps. The batterie is at 73%.
Support is not able to be contacted - very annoyed with Fitbit and google
any advice. There is no dealer here on the island I can go to . As I bought the watch at the airport
Hi @machinecooks ! Glad to see you around the forums.
I appreciate your message, and I'm sorry to hear that your Charge 6 is unresponsive. Thank you for the troubleshooting steps you already tried. I understand your feelings about this situation, and I'll be glad to propose you some steps.
Firstly, could you please verify if there is a firmware update available for your device ? In order to do so, please follow the steps shown in the following help article : How do I update my Fitbit device?
Then, try to manually sync your device :
If you experience some troubles with the syncing procedure, please follow the steps listed here : Why won't my Fitbit device sync?
Finally, try to change the clock face as explained here : How do I change the clock face on my Fitbit device?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
Hi @machinecooks and thank you for your message and for the additional information.
I appreciate all the troubleshooting steps tried.
May I suggest you to set up your Charge 6 as a new device ? The issue could be due to a pending firmware update. If an update is available, the setup process will complete it.
To do so, please try to follow the steps shown in the following help article : How do I set up my Fitbit device?
unfortunately this is not possible as the screen doesn't work at all anymore and I cant sync my phone to the tracker at all... I tried all kinds of advices I could find but nothing worked...
I couldn't update the tracker as it would not let me do it.
I am really really disappointed with this NEW charge. I am waiting now for fitbit to get back to me to replace my tracker... but really not sure if i want that one again...
also a big issue is... that the battery life was supposed to be up to 7 days but that changed in the last 2 weeks as well from 6 days down to 3-4 days battery life.
And another issue is the plastic strap. I tried all recommendations to stop it from reacting to my skin but I actually get open wounds from it. Had the same issue with the strap from my charge 2, once i bought a cheap replacement strap the issue was resolved- maybe fitbit should do something about that too.
Best AnswerHey Mario you were so helpful last time maybe you can help again?
my charge 6 tracker doesn’t restart at midnight. I wake up with 17000 steps at 3am and 1800 cal burned. Then during the day I got all of a sudden the 10000 notification and then a couple hours later again, I tried to reset etc but nothing worked so far
Hi @machinecooks and welcome back to the forums.
I appreciate your message, and I'm sorry to hear that you are seeing these inaccurate steps and calorie count on your Charge 6.
Could you please verify if your Fitbit app is running the last update? How do I update the Fitbit app?
If the issue remains, please try these steps:
Please note that this procedure will delete your data on the watch, however your information stored in the app will remain. That's the reason why I suggest syncing at first.
