01-01-2024
05:14
09:05
ManuFitbit
01-01-2024
05:14
09:05
ManuFitbit
I just moved from my old Charge 4 to Charge 6. I set up my charge 6 3 days ago, and the battery seems to be lasting less than 24 hours.
Has anyone else experienced this? Hoping for suggestion on what settings to look at. Thank you.
Moderator edit: clarified subject.
Best Answer01-01-2024 06:22
01-01-2024 06:22
I'd imagine that either something is running in the background that should not be, or your watch is faulty. First thing to try is to shut it down, after that, a factory reset. If this does not help, it's likely a faulty watch.
Best Answer01-01-2024 15:01
01-01-2024 15:01
My charge 6 has lasted 4-5 days on one charge. However, I went out for a long hike and was tracking, and my battery was down to 27% by the time I was done. (Was hiking about 5-6 hours).
01-03-2024 09:03
01-03-2024 09:03
Welcome to the forums @VickiLeeW @SunsetRunner
It's good to see you participating in the community @Mcav75. Thank you for advising.
Thank you for taking the time to share the details regarding the situation with your devices. I'm sorry to know the situation.
In addition to the suggestion above provided by @Mcav75, I'd recommend you take a look at this help article: Can I extend my Fitbit device's battery life?
Best Answer01-03-2024 09:09
01-03-2024 09:09
Hi again @VickiLeeW,
My Charge 6 is tracking everything, and has GPS set to "dynamic". My first 24 hours of use, which includes initial set up have led to it using 9% of battery. I have disabled always on screen and set the screen brightness to "dim". Other than that, it is all go. The last 24 hours also included a 15 minute HIIT session, which it tracked very well.
In this respect, something is definitely not right with your watch.
Best Answer04-22-2024 00:30
04-22-2024 00:30
All these issues with short battery life are due to Fitbit sending a bad update to the software. Users have done nothing wrong or different. Fitbit have broken our watches making them useless. I know this as my friend Simon works in very complex IT systems and he and all his colleagues are aware of the mistakes.
Fitbit sent me a replacement watch for free and it's exactly the same. We need to group together to demand redress.
