Hello @OMG666441
Sorry to see you're having issues with sleep tracking.
By any chance, are you also having issues with heart tracking? Do you see a green light on the back of your Charge 6? You can check by placing your finger across the back of the device. You should the green light when you lift your finger.
If you don't see a green light, the first place to check is in the Settings menu of your Charge 6 & check that Heart rate is turned on.
Best AnswerI have the same problem and I get the green light and Heart Rate is turned on. The sleep score has never been missing before this morning.
Best AnswerHello @OMG666441 & @Stearman
I'm wondering if there was a problem on the Fitbit side. I didn't get any sleep data on Tuesday morning (30 Dec 2024). Editing my sleep log in the app didn't work, either.
Have you gotten your sleep data since then?
Sorry to see that you're continuing to have issues with your Charge 6.
Have you had a chance to confirm that Heart rate is still enabled in the Settings menu of the Charge 6?
Have you restarted your Charge 6 lately? If not, that would be a good first troubleshooting step.
