02-24-2025
07:52
19:47
ManuFitbit
02-24-2025
07:52
19:47
ManuFitbit
For the past few days, my step count has been changing (usually reducing) by hundreds out of nowhere.
This morning, for example, a few minutes after I finished a walk, 1000 or so steps just disappeared from the day's total. I know this walk route well and it was the first thing I did in the morning, so I am sure the total before the 1000 steps were removed was accurate, which rules out this being a "correction". As another example, a few days ago, I was notified three separate times in the span of a few minutes that I had achieved my step goal (which is how I noticed the problem in the first place).
I sync the watch to my Samsung phone as I always have. It might be happening around when it is trying to communicate with my phone, but it is difficult to tell.
A bit of poking around the internet suggests that many users are having this problem and that it is not specific to the Charge 6. Is there any information on when this bug will be fixed?
Moderator edit: clarified subject.
03-08-2025 12:13
03-08-2025 12:13
I have been having this same issue for the past week. Frustrating thinking you have met your goal, only to find later in the day, that you haven't. I have an iphone 13 pro max 18.11. I hope you can fix this! Thank you
Best Answer03-27-2025 13:54
03-27-2025 13:54
Hi everyone and welcome to the new members.
Thanks for the steps that you tried and the additional information.
I'd like to share with you that this issue has been fixed. Your Fitbit device should be counting your steps correctly now.
Once again, I appreciate your patience.
Best Answer03-27-2025 17:24 - edited 03-27-2025 17:26
The issue has not been fixed. I just did a 2 mile hike but it more than doubled the steps and distance. Very frustrating.
Best Answer03-28-2025 13:49
03-28-2025 13:49
It is definitely not fixed. Please try again.
Best Answer03-28-2025 15:36 - edited 03-28-2025 15:40
I updated my charge 6 yesterday and now I’m having weirdness. My Fitbit, which is what I wore all day and during my 2 mile walk shows 5621. However, the app is 5758. So the phone is showing more steps that my Fitbit. I don’t have any other way of getting these extra steps so I attribute the weirdness to the update I did yesterday. I have a Charge6 and my iPhone 16 Max Pro running 16.3.2. Thanks!
Best Answer04-22-2025 09:00
04-22-2025 09:00
It's happening to me on a daily basis now. Please fix it.
08:30
16:13
ManuFitbit
06-12-2025
08:30
16:13
ManuFitbit
I m experiencing the same problem with step count distance/distance suddenly changing for no reason. Fitbit App and Charge 6 will say I have gone a certain number of steps/distance and then suddenly change several hundred steps forward or back with in a time period of 30 seconds or so, sometime moving forward and back within the same time period. I had a similar problem with a Fitbit Sense and got a Charge 6 in March 2025. It did not seem to have a problem until the last 10 days or so, and it suddenly started for the Charge 6 and now occurs every day, at multiple times and it is very frustrating as I can’t rely on my app/watch to give me correct information from minute to minute. I am using an IPhone 14 ProMax with IOS version 18.5. If I can’t find a solution. Anyone have any suggestions for a remedy to this problem.?
Moderator edit: formatting
07-12-2025 10:19
07-12-2025 10:19
I just upgraded from a Charge 4 to a 6, and this started happening immediately. It is not fixed.
Best Answer10-13-2025 16:09
10-13-2025 16:09
This is happening to me Fitbit 6 Samsung S21 Ultra - thinking of ditching Fitbit and going to Samsung... it is so unreliable, it is demoralising and useless!
Best Answer11-13-2025 09:38
11-13-2025 09:38
This definitely has not been fixed. I’m using a Charge 6 and iPhone SE 2020. The steps jump around so wildly I don’t know what the real number is. It’s pretty frustrating.
