08-23-2024
00:26
08:01
LizzyFitbit
08-23-2024
00:26
08:01
LizzyFitbit
I have a Charge6 and it has stopped mapping my exercise. I like to see if my miles are getting faster for a PB. I have GPS enabled on the actual Fitbit. Am I overlooking something? Anyone else having this issue? I have been wearing it for 4 months and it used to map
08-27-2024 04:07
08-27-2024 04:07
@Donal.OM On your Charge 6, when you tap the Walk exercise, swipe up from the bottom and make sure the GPS is turned on. Perhaps it was toggled off for some reason.
08-23-2024 02:33
08-23-2024 02:33
I have had the same issue for the last couple of months. It used to map my journey but does not any longer. I have gone through all of the settings and even kept GoogleMaps open while exercising and it does not map the journey. I suspect it is something that was disabled in the last software update.
08-23-2024 03:22
08-23-2024 03:22
@luanexi2 @Donal.OM Just to confirm, your GPS settings are turned on and your starting your run from the Charge 6 and you're selecting "Run", "Walk", or "Hike", correct? And you are still not seeing a map in the app when you select "Exercise Days" and then tap on the tile to view all your workouts? If possible, can you post a screen shot of what your app looks like?
I would restart your watch, disconnect and reconnect to your phone's bluetooth or possibly even do a factory reset if the issue persists.
08-23-2024 06:31
08-23-2024 06:31
Hi Heather,
Yes, I did all of the things you suggested. Screen shots below of today verses when it was mapping.
08-27-2024 04:07
08-27-2024 04:07
08-27-2024 05:57
08-27-2024 05:57
Wow!! Thanks, Heather!!! I don’t how that got toggled off, but I was completely unaware of the switch. That’s great and thank you for responding. 😃
