03-10-2024
11:49
12:27
ManuFitbit
03-10-2024
11:49
12:27
ManuFitbit
Once I did the update, the time I had set for my hours to move between changed. I have tried resetting them and it will not save my changes. Same thing happened on my fathers Fitbit and I can not change the time on his either.
Moderator edit: clarified subject.
Best AnswerHello @MsJenn28
If you are in the USA, I suspect that your current issue is likely due to the change to Daylight Saving Time.
When this has happened in the past due to the time change, the app is usually working properly within a day.
Hi @MsJenn28 @yahoodude. Welcome to the community forums.
Thank you for sharing the inquiry regarding the difficulty with the time on your tracker.
I hope that you are no longer experiencing the difficulty but if so, please follow the steps listed here below:
Restart your device as indicated here.
Sync as usual you do it. If you have some difficulties to sync, please visit: Why won't my Fitbit device sync?
In addition, follow the steps listed in this help article: How do I change the time on my Fitbit device?
