11-22-2024
05:08
13:49
ManuFitbit
11-22-2024
05:08
13:49
ManuFitbit
My Charge 6 won't re-charge. I have cleaned the connectors and tried various points to plug in the cable and I have long-pressed the button on the charging cable but nothing is working.
Moderator edit: clarified subject.
How long was it left on the charger? In order to get a good charge, it needs to be on the charger for at least 2 hours.
Also, did you try different outlets?
one cruise ship at a time!
Welcome to the forums @TonyMP.
Thank you for providing the inquiry regarding your Charge 6. Thank you for trying to fix it on your own.
Please confirm that you have followed the steps suggested in this help article.
Thanks for your help @DramaQueenDiva
Hi @SKOTT132. Welcome to the forums.
Thank you for letting us know that you are experiencing the same behaviour on your tracker.
Please, confirm that you tried the steps listed in the help article: Why isn't my Fitbit device's battery charging?
In addition, check out if your device is updated: How do I update my Fitbit device?
Thanks for responding @SKOTT132 and for confirming that you performed the steps.
Since you tried the steps and they didn't work, and you are still experiencing a charging issue, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
I’ll keep an eye out for your response specifically, so please let me know once you’ve filled it out.
Best AnswerHi @KMits and @Wzq , have you tried the steps mentioned by @ManuFitbit ?
It may also be helpful for you to try different chargers and outlets if available to help narrow down where the issue is. I would also clean the back of all devices and the charging ports in question before beginning your tests. If that doesn't work, you can contact Support via chat at the bottom of this page and ask for a Battery Test to help diagnose the issue.
@TonyMP I'm glad you were able to exchange your device. Please let us know how it goes.
one cruise ship at a time!Hello @Laurie50
Have you tried the other recommended troubleshooting steps in the link that the Moderator posted on 23 Nov 2024?
