02-13-2024
12:49
15:50
LizzyFitbit
02-13-2024
12:49
15:50
LizzyFitbit
My Fitbit wouldn’t sync earlier today so did a reset and lost the data that was stored on the Fitbit (now seems to have lost a few hours of actual). Can this be recovered?
02-13-2024 13:57
02-13-2024 13:57
I had the same issue a few weeks ago. Contacted Fitbit support and they said it could take up to 72 hours for the data to sync. It never did. I reached back out and then they basically told me it won't. Hope you have better luck than I did.
02-13-2024 14:30
02-13-2024 14:30
Hello @Lvernon
Did you restart your Charge 6 either from the Settings menu on the device or by using the charging cable that came with your Fitbit? If so, your data should still be in your tracker and should eventually sync. Hopefully, this is the case.
If you used Clear Data from the Settings menu on your Charge 6, then that was a factory reset and your data that wasn't synced was lost.
Although this won't help you now, this help article (<-- click link) has the recommended troubleshooting steps to try when you're having syncing issues.
02-13-2024 14:36
02-13-2024 14:36
Thanks, I did not clear the data from the Charge 6. I only removed it from the app, then re-added it.
02-13-2024 15:00
02-13-2024 15:00
Hi @jamiefromwi
I'm not sure why your data didn't sync to the app when you re-added it. I know there are users who have more than 1 Fitbit device and regularly switch between them.
From what I've read, Fitbit devices usually maintain tracked data for about 7 days. As far as I know, your data should have synced when you re-added it to the app.
The next time you're noticing your data isn't syncing in the app, try doing a force stop on the Fitbit app from the App settings on your phone. Yesterday, my data wasn't syncing in the app. I did a force stop on my Fitbit app, opened the app, and my data finally synced. I did a manual sync to make sure and all was good.
02-26-2024 12:19
02-26-2024 12:19
Why are there so many issues with the Charge 6?
Is this a defective model?
07-03-2025 15:58
07-03-2025 15:58
Starting to feel that way. I have had many Fitbits over the years and this is the only one to have issues and it gives me trouble way too much. I could not get it to sync and followed instructions to reset just like OP. It lost 3 days worth of data.
07-04-2025 08:00 - edited 07-04-2025 15:54
Hi @AnniePlantBased Did you restart your Charge 6 or reset it? They are two different things. You should not lose data with a restart. You will lose unsynced data if you reset it.
Laurie | Maryland
07-04-2025 14:37
07-04-2025 14:37
I went to settings, scrolled all the way down and pressed restart device. It might not should happen but it did. And from the replies in this thread I can see I am not the only one it has happened to.
07-05-2025 06:11
07-05-2025 06:11
@AnniePlantBased I can't explain why this happened to you. In all my years, I never lost data with a restart.
Laurie | Maryland
