Charge6 inaccurate distance / GPS
More than 1.5km error in distance calculated on walk. GPS track shows inaccurate route.
3 REPLIES 3
Your green example shows major issues in keeping a gps lock. Are you using the connected gps on the phone, or the very small antenna on the Charge 6?
Was the sky very cloudy? Was there a lot of tree coverage?
Not connected to phone, And yes its a tree covered area
Hi @kavithakavitha ! It’s great to have you on board!
@Rich_Laue I appreciate your support!
@kavithakavitha I'm sorry to hear that your GPS map is not accurate.  Thank you very much for all the information.
Since the area where you exercise has many trees, I suggest you restart your Charge 6 and try a run in a different area, one with fewer trees and not too many buildings, so you can compare the results.
Additionally I suggest you to take a look to the following article: How accurate are Fitbit devices?
