08-06-2025 03:50
08-06-2025 03:50
When I first got my Fitbit charge 6 I had to wear it for 7 nights before the daily readiness score would show up. No problem with that, as obviously that was all part of the "set-up" process. After having this Fitbit for 7 months now, what I'd like to know is:
If I forget to wear it to bed for 1 night after wearing it to bed for months on end, it seems I then have to wear it again for another 7 nights for the daily readiness score to show up again? Is there a "work around" for this or is there something in the settings I can adjust to stop this so it continues to pick up recording the the readiness data straight away (ie the next night) if I forget to wear it for 1 night.
This has happened on the odd occasion when I've charged it at night, then forgotten to put it on again before going to bed. Seems a bit ridiculous, in this day and age if it doesn't pick up tracking the readiness score straight away again!
Best Answer08-06-2025 11:36
08-06-2025 11:36
Hello @Sporty1
According to the help page on Daily Readiness (<-- click), it looks like a break in wearing the Fitbit at night means one has to restart the 7 nights in order for the algorithm to generate the score.
It doesn't look like there's a workaround for this that I could find.
08-07-2025 20:20
08-07-2025 20:20
Thanks for your reply, I thought that might be the case! It's a bit annoying really, but I'll just have to make sure I don't accidentally forget to put it back on before bedtime! Hahaha!
08-08-2025 11:13
08-08-2025 11:13
Hi @Sporty1
If I happen to come across a workaround for the Daily Readiness score when one forgets to wear their Fitbit at night, I'll be sure to report back and share it with you.
However, I have a strong suspicion that there isn't one...yet.
