Welcome @forsyth to the Fitbit Community! It's great to have you here!
I'm glad to help you with the missing sleep score.
If you received a sleep log, but it only includes your sleep pattern, you won't receive slee score. You need to receive sleep stages in order to get a sleep score.
What kind of sleep record did you receive?
If you did receive sleep stages but you still don't see a sleep score, note that it may take a few minutes for your sleep score to appear.
If you have waited enough, update the Fitbit app to the latest version. For instructions, refer to How do I use the Fitbit app?
08-05-2025
17:23
17:07
ManuFitbit
08-05-2025
17:23
17:07
ManuFitbit
I have installed the app on my tablet and taken it off my phone I'll see
how that goes
Well that didn't work still no sleep score, everything else showing up as it should. Very fus
Best Answerreboot phone.
restart watch.
Then, if android, go to settings/apps/fitbit and clear cache and data (note - this will reset anything you have changed in the fitbit app.)
start fitbit and log in and then sync. (you may have to re-pair bluetooth.)
Hope that helps...
