08-20-2024 06:12
08-20-2024 06:12
When "Water Lock" is enabled, the watch should not display any prompt that requires user to tap on "Got it" prompt because the taps on the screen are not detected in this mode.
The only way to tap on the prompt is to disable "Water Lock" first, which is impossible while doing extreme water sports.
So when this happens, the watch becomes useless because the time is blocked.
