I’ve been manually starting ‘Workout’ for months with no issue. Starting yesterday, in addition to the manually started workout session, I am seeing that my workout was also auto detected as ‘Aerobic Workout’ and it looks like I worked out twice in the app (but it was really only one workout). Nothing changed in my Fitbit settings so I’m not sure why 2 workouts started showing up in the app. I don’t want to disable auto tracking. I have an IPhone 14.
Hello again. Thanks for the feedback.
We’ve fixed the bug that caused some Activities/Exercises to appear as duplicates in the Fitbit app.
You don't need to update your Fitbit app for this fix to take effect. While new duplicates won't appear moving forward, you may still see some duplicate logs from before the fix was implemented. You can easily remove those by following these steps:
Hi, @Jazzy4Ever , you should definitely be able to have auto tracking turned on while still being able to track manually when you choose. I think it is likely that this is a temporary glitch, as I know that Google are working on some updates to the Fitbit app, so I would recommend deleting the duplicate workout and carrying on as normal, but please report back if the double workouts continue to be logged so that the developers can look into this.
Thank you for your report, and welcome to the Community Forums!
I am seeing this also. the duplicate starts a minute or two after the one I started, and doesn’t have the GPS map. I’m going to delete them. Seems similar to the duplicate weigh-ins Fitbit has (had) on the aria scale.
Welcome to the Fitbit Community, @Jazzy4Ever. Thanks for getting back to us @CareyS.
Thanks for the feedback. We are aware of a bug that is causing some activities and exercises to appear as duplicates in the Fitbit app and are working on a fix.
Thanks for your interaction @Julia_G.
Stay tuned as I'll be posting any updates as soon as I get them.
Thank you! I am no longer seeing duplicates.
