12-03-2023
02:08
10:49
LizzyFitbit
12-03-2023
02:08
10:49
LizzyFitbit
Hello, I am on the Fitbit Charge 6 and I find it impossible to do an EGC.
On my bracelet, when I want to run a test, it tells me: impossible to find the phone.
I then open the Fitbit application and go to the egc history, I try to restart the test and still the same, it does not work.
I tried everything, uninstalling the application, resetting the bracelet, looking at the application permissions. The only thing I can't try is to uninstall then reinstall the EGC application, it doesn't work.
I need help please
Little precision, im form France and it's enable in my contry 🙂
A warm welcome to the forums, @SekaP.
Thanks for the detailed information, and all the steps that you've tried prior to posting. I'm glad you got the ECG working on your Charge 6 and I'm sure your post will help other community members having similar issues.
In case you have some spare time, I'd like to invite you to visit our Health & Wellness board where you’ll find great tips and encouragement from other members. Have a good one!
Best AnswerHello @Sinatra87
According to the Fitbit Irregular Rhythm information page (<-- click link), it shows the ECG app as available in Australia.
Welcome on board, @Sinatra87. @RiekoC Thanks for your help!
@Sinatra87 With the link shared by our friend you'll find the complete list of countries that support this feature. Since Australia is one of them, I'd recommend this help article which explains more about the ECG app and how to use it.
Best AnswerHello @jodomofo
I hope you don't mind that I jump in and answer your question.
To check/change your location:
Please let us know if you still need help in setting up your location/country in the Fitbit app.
Hi there, @jodomofo. @RiekoC Thanks for your amazing help!
@jodomofo Thanks for joining this thread and please follow the instructions shared by our friend @RiekoC. You should be able to install the ECG app on your Fitbit device afterward.
I'd also suggest this help article which provides more information about this app and how to check your results.
