Eufy scales
Hi,
I got a charge 6 for Xmas, and linked the Eufy scales which I use everyday to it. It downloaded all the data from the past couple of years, and then disconnected. I've tried reconnecting it, but it won't stay connected and I get regular messages on my fitbit to say that it has failed to connect with an app (it doesn't say which one but i presume it means Eufy). I've followed the advice on the forum for connecting, but no luck. Anyone got any suggestions? (I should say this may be an issue with Eufy - fitbit says it is connected, but Eufy says it isn't).
Thanks.
3 REPLIES 3
Hi @Mirkle
Have you tried disconnecting/revoking the connection on both sides and then started the entire process again?
In the Fitbit app this is done by tapping your profile picture - Fitbit settings - connected apps - manage connected apps.
Community Council Member
Nathan | UK
Looking to get more sleep? Join the conversation on the Sleep better forum.
Thanks, it seems to have reconnected. I'll get back to you if it
disconnects.
Regards,
Mark Ellis
Ok that's good to hear, hopefully it will be trouble free from now on.
Nathan | UK
