11-28-2023 08:48 - last edited on 11-28-2023 09:30 by RodrigoMFitbit
Is anyone else getting poor battery life? Just got my Charge 6 and I'm using basically the same settings as the Charge 5 I previously had (very battery conscious / conservative use), but I'm getting about half the life - about 3-4 days. Super disappointing.
11-28-2023 09:50
11-28-2023 09:50
@Dayai Welcome to the forums. I will gladly help you regarding your Fitbit Charge 6's battery life.
Thanks for the explanation. Please note that many factors are involved. Have you been tracking your trainings with GPS? The amount of notifications received may also affect the battery life because of the screen lighting up and the vibration. I recommend you take a look at the following article: Can I extend my Fitbit device's battery life?. Here you finde tips for this situation.
11-28-2023 19:24
11-28-2023 19:24
Mine is much less, like 12 hrs, I just updated my watch software and now it is not turning on or charging at all. So bummed out
11-28-2023 19:29
11-28-2023 19:29
Thanks, but yes I went through all those suggestions, and I really don't use the things that seem to have the biggest impact on battery. I have a lot of default settings, and like I said am using the same settings as I had with my Charge 5, but getting much much less out of it. I'm starting to cycle through and turn absolutely everything off just to get a baseline.
11-30-2023 15:11
11-30-2023 15:11
For what it's worth, I'm still testing things, but I'm getting much better battery life now. It was either turning off reminders to move, or potentially was the recent software update. I can't believe that having reminders to move, only on weekdays, only for 8 hours a day would have that big of an impact on battery. Never was an issue on my Charge 5.
05-05-2024 12:56
05-05-2024 12:56
Are you replacing faulty Fitbits with new ones? If not, I will be finding a suitable replacement somewhere else.
05-05-2024 19:34
05-05-2024 19:34
Head over to the charge 5 forum and you’ll see everyone is having battery issues. Missy likely due to the firmware update. Fitbit refuses to take responsibility
