11-05-2023
06:15
11:15
RodrigoMFitbit
11-05-2023
06:15
11:15
RodrigoMFitbit
My charge 6 doesn’t sync on its own. I have to pull the screen down on my phone app and then it takes forever to sync. This is super frustrating.
Suggestions welcome
@Triletics Thanks for your help!
@Duchess2023 @SunsetRunner Welcome to the forums. I will gladly help you sync your Fitbit Charge 6.
I suggest you take a look at this article: Why won't my Fitbit device sync?. Here you find tips for this scenario. In case you have an Android device, please take a look at the following article: Why does the Fitbit app need to run in the background on my Android phone?.
Best AnswerJust bought a charge six today. It will not connect to an iPhone 14. I’ve done every remedy that Fitbit suggests. Of course when you try to contact support all you get is a blank screen. I think Fitbit is allergic to providing support.
Having same problem. I have to manually re-sync the iphone 13 everyday to the 6 charger. Wish I hadn't updated to this Charge 6. I've reset the phone, the charger, etc.
@Candyadams @Cathyrunner Thanks for your post about the Charge 6 not syncing to your smartphone. @Candyadams Do you also have an iPhone?
I suggest you take a look at this article: Why won't my Fitbit device sync?. Here you find tips for this scenario. Make sure that the Fitbit app is allowed to run in the background.
