I got a notification that my battery was low so I put it on its charger. I returned a half hour later and it hasn't charged. I've tried moving it every direction but it seems like the charger has stopped working. How do I fix it? I got this for Christmas and am surprised I already have an issue after only using for a few weeks.
Best AnswerHello @Hdubs
This page has the recommended troubleshooting steps to try: Why isn't my Fitbit battery charging? (<-- click link). Hopefully, one of the recommended steps will work and get your Charge 6 back to charging properly.
If you try all the steps without success, then you should contact Fitbit support (<-- click link) .
Best AnswerHello, I am having the same issue today (1.12.2024). I have tried all the troubleshooting recommendations and none work. I tried to reset it on my iphone, but of course, it can't reset because there isn't enough charge on the watch to do that or to download some update that is pending. So frustrating. I got the watch in early October.
Best AnswerHello @ArcherD
Since you've tried the recommended troubleshooting steps without success, then you should contact Fitbit support. You can use the link in my previous post.
Welcome to the community @Hdubs @ArcherD
Thank you for sharing the inquiry regarding your Charge 6. Sorry to know the inconvenience that you are experiencing.
@Hdubs I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed. Please, keep an eye on your inbox.
In addition to the help article mentioned by @RiekoC, I'd recommend this other one, that helps you to have clean the charging contacts on the device and avoid charging or heart rate issues.
Thanks for helping @RiekoC
