04-07-2024
07:53
11:59
AndreaFitbit
04-07-2024
07:53
11:59
AndreaFitbit
Hi,
Anyone know how to get the charge 6 to connect to gps? If I use my phone to start activity it tracks it and has a map. However if I start from my watch it does not connect.
All my settings are correct, I have restarted, reinstalled, forced stop turned blue tooth on and off, reatarted phone, rebooted tracker and cleared data and repaired. Nothing is working I have only had this 4 months. I have turned gps on in both the walk and run shortcut. GPS is set to dynamic mode, I sometimes don't walk with my phone. Never had a problem with the fitbit up untill last Thursday when I had to restart as it didn't track my run on gps. I run alot so the map is important for pace and heart rate etc.
Anyone else had this issues?
Moderator Edit: Formatting.
Best Answer04-07-2024 16:00
04-07-2024 16:00
Only option that mostly works is "Phone" mode. "Dynamic" and "Built-In" are mostly useless. Since I got Charge 6 (shortly after release) I haven't captured a single run using built-in GPS. Either doesn't connect at all or disconnects after a while and never reconnects (shows "GPS off" screen). No fix for it. It is what it is.
Best Answer04-11-2024 12:15
04-11-2024 12:15
Thank you for the reply,
Hopefully at some point fitbit will look in to this issue as it appears it's affecting a lot of charge 6's. Not ideal as it's an important feature. Thanks for the reply again.
