Hello everyone, I want to buy a fitness tracker and Charge 6 seems to be the perfect one (to me). So I went to the store but the guy informed me that not every system is compatible with Charge 6 especially not Huawei and Honor.
I could not find any information for this case so I'm asking here.
Short: Can I use Charge 6 for my Honor 90 Lite? Is it compatible, are there any problems?
Best AnswerHi @SaMikael you can find more information in this article - click to view. If it's not a compatible device, you'd have trouble setting up and syncing to your phone. I did a search of the forums to see if anyone else had problems with the Honor Lite phones, There were a few posts, but nothing after 2021 until your post. None of those people seemed to be able to get it to work. One person mentioned that once they switched to a Samsung phone, they had no problem using their Fitbit.
I had a Honor phone before and Huawei tracker. I am not sure why you think the change 6 is the perfect one. A Huawei tracker will be either far cheaper like the band 9 or far more features like the Huawei fit watch. For sleep accuracy the Charge 6 is better but does not give you real time sleep updates through the night. For running the Huawei devices are pretty good. For style the charge is better the charge 6 also has loads of straps and things. There is also fitbit support and a lot of users like this forum. So yes there are many advantages but if just to measure you exercise and to work reliably I would tend to think Huawei, also way cheaper. Having said that a Fitbit is a type of clothing/watch and like a Rolex people will pay a crazy high price for style and brand so in this context the fitbit could be considered a bargain
