I know how to set one alarm on my Fitbit Charge 6 but I need to set up 4 alarms.
Info on Fitbit Community says I can do this from my computer using the gear icon and selecting Silent Alarms then Add Alarm. I find no such category.
Would someone give me the details how to set this up? I use Apple IOS version 17.2.1. Thanks.
Hi @CocoHK using my Windows computer, I found what you need. Let's see if I can guide you to that area. Go to your Dashboard. From the pull down menu upper right, select your device. That should take you to a new window where you will see your device name. Under that you'll see silent alarms and a few other possible settings. Click on silent alarms and see if you can get things done that way. Let us know how things go for you.
This article will tell you how to set the alarms directly on your Charge 6 - click to read
Hi @j9harris did you click to read the article that gives step by step directions?
I'd also like an answer to this question. Can only set 1 alarm from the actual device (charge 6). Can not find anywhere on the online dashboard or within the phone app that allows alarms to be set. In the instructions linked by @Odyssey13 it states that for the charge 6 alarms can only be set from the device. Surely a watch this expensive allows more than one alarm to be set at a time!!!
On the device under the first alarm. When you swipe up it says New Alarm in a yellow box. Click it and add the alarm.
I found how to set multiple alarms (just swipe left to the "alarms" section, then scroll down to the "new alarm" button), unfortunately you can only set eight alarms. This is frustrating for me, because I use this feature as a movement reminder that is louder and at a more convenient time than the default movement reminder, but I can only use it for eight hours rather than 10 as I would need to.
Can you please offer direction for the 6.
i want multiple alarms on daily repeat.
there is no “add alarm” when i scroll down. I just see the smart alarm feature.
im very disappointed with the lack of alarm options
Best AnswerI cannot upload a video here, but I just verified it and it’s exactly how I explained it. Try again and it should work.
if you’re seeing the smart alarm prompt, that it means that you have already touched an alarm that you are then offered to configure. You need to stop one step behind, where the alarm is shown,, not its configuration options. Hope it helps!
Best AnswerMy old Inspire 2 could set multiple alarms from the app. The Charge 6 has no silent alarms option on the app itself, it's gone! I'm so disappointed in what I'd hoped was an upgrade.
Best Answer@Itshouldbeismpl please follow the link that @Odyssey13 posted. On this page you will find instruction for setting the alarm on the device or through the app. The instructions on the page state that on the Charge 6, the alarm is set through the devorce.
Best AnswerPlease my read my earlier post. I have already read the link. You can not set up alarms via the app and that was the original question. You have to do it through the tiny device's screen and all the alarms says "wake up".
Best AnswerOn the device:
1)Swipe left to "Alarms" (don't click on the alarm icon!)
2) Swipe upward, select "new alarm"
