11-20-2023
23:56
09:00
LizzyFitbit
11-20-2023
23:56
09:00
LizzyFitbit
Is there a solution to Fitbit watches recording the wrong time for exercises and sleep despite the clock being correct?
I have the Charge 5 and ever since the daylight saving time changed all my sleep and exercise records have been shifted by an hour.
My brothers Pixel watch is even worse and we tried a lot of things to solve it, it's shifted by 4 hours.
Both watches tell the correct time, it's just the activity recording that's wrong.
Hello @hanma93
I know that this year's time change to Standard time caused issues for some users. But that seemed to get resolved within a day or so.
Have you & your brother checked the Fitbit app settings to confirm that you have Automatic Time Zone & Automatic location enabled? To check:
If everything was enabled & correct, you might try turning off Automatic time zone & location, selecting sometime different, and manually sync. Then, go back to the App settings page, enable Automatic time zone & location, followed by a manual sync.
Hopefully, this will correct the time for your tracked sleep & workouts.
You should be able to edit the time of your sleep & workouts in the Fitbit app to show the correct times.
