01-31-2024
17:36
07:38
CrisVillaFitbit
01-31-2024
17:36
07:38
CrisVillaFitbit
I have the Fitbit charge 6. When I check to see if the Fitbit is up to date the screen just flashes the Fitbit logo. What am I doing wrong? In the past it would either say up ti date or offer the Porto install the update. The app stalls there and I have to shut it down to even go back to the previous screen. Can anyone explain this to me or is anyone else experiencing this issue?
Thank you!!
Moderator edit: edited title to clarity
Welcome back to the community, I'm glad to see you once again here, @Spearguy.
Thanks for explaining this situation in regards to the update of your Charge 6.
It is normal if you don't get anything going after checking for the update, I was able to confirm your Charge 6 firmware is updated. I'm not sure which steps you're following to update it, but these are the ones you need to follow:
If you have trouble updating your device, see Why can't I update my Fitbit device?
Hi CrisVillaFitbit!
I've done everything you said to do and I believe my Fitbit is updated, but now in pink at the bottom of the screen it shows "Remove This Charge 6." I assume I don't want to click that, but wanted to make sure...
Hello there and welcome back, @Spearguy.
I'm glad I was able to help you, @Spearguy, and thanks for posting since this will help other users in the community.
And welcome to you, @wilddog789, it is always nice to see a new user posting.
Yeah, I would not recommend you to click on that since it will remove your Charge 6 and you'll need to set it up once again.
