How to change pin for Google Pay? Using Charge 6
ANSWERED
I've just set up Google Pay and set the code to a high number, now every time I want to use my card it takes about 20 seconds to enter the code. This means that the feature is completely useless if I have my phone which is a lot quicker. Is there any way to change your Google Wallet pin? Also, I'm using an iPhone so can't get onto the Google Wallet app itself only through Fitbit. Any help would be appreciated.
Moderator edit: edited title to clarity.
1 BEST ANSWER
Accepted Solutions
I've just figured it out. On the fitbit app click on the top left where  it shows the charge of your devices then select charge 6. Scroll down to Device Lock. This let's you change the unlock PIN for the device.
16 REPLIES 16
Hi, @hfisk1 Welcome to the community, I'm glad you posted for the first time!
Thanks for asking this interesting question, I imagine how this situation when entering the PIN could impact your purchases using the Charge 6.
You can follow these steps to change the PIN, it will be directly using your Google account:
- Open your Google Account. You might need to sign in.
- Under "Security," select Signing in to Google.
- Choose Google Account PIN. You might need to sign in again.
- Choose Change PIN.
- Choose a strong PIN, and follow the steps on the screen.
- Select Save.
I hope this information finds you well!
Step 1: Open your Google Account. You might need to sign in.
Where do I do this?  On my phone?  On my laptop?
This answer isn't very useful.
I tried this but this does not change the PIN to unlock Google Wallet on the Charge 6, I think it's a different PIN to access your Google account elsewhere.
Is there a way to change the unlock PIN on the Charge 6?
Hello @shyam890, welcome to the community and thanks for explaining your situation and the way in which your solved this in regards the PIN to input in the Google Wallet feature.
This will help other users in the community, I truly appreciate your help!
@shyam890's method worked for me and my Fitbit Charge 6.  Thanks so much.
Hi there once again, @mdn2021.
I'm glad this worked for you and thanks for posting it, since this will be helpful for other users with the same situation.
Hi
I seem to have a pin set for google wallet but must have set it accidentally
I have gone to device lock to change but it asked for the old pin first which I don’t have !!!!!
Thank you so much. That work perfectly fine and faster. 😊
Welcome back, @Gurvi and I'm glad it did work for you!
@GMW01 welcome back for you too!
- Select Save.
In case others are struggling to spot it, device lock is now hidden under Device preferences (rather than, say, Google Wallet or System).
Thanks 🙂
I figured out that once u put the pin in once it wont ask for it again unless you reset the watch or take it off your wrist. As long as it has a pulse it can't be stolen so doesn't need a pin each time.
I went to device settings and device lock and change my pin. I keep getting asked for my old pin before I can  enter a new one. I don't remember my old pin. And I keep getting locked out
I have the same problem. I don't remember where my Fitbit Google Play pin
My Google account is much longer than four digits. Nor can I find any of this:
- Select Save.
