01-09-2024
14:43
11:00
RodrigoMFitbit
01-09-2024
14:43
11:00
RodrigoMFitbit
How to I view the heart rate graph for my exercise session?
Best Answer01-09-2024 15:18
01-09-2024 15:18
This is how it works for me on Android when it comes to recorded running sessions. You click on the Exercise days widget on the front page, then you click on the exercise you want to check the rate graph for and scroll down until you get to the graph.
01-10-2024 10:59
01-10-2024 10:59
@SunsetRunner Thanks for the explanation. Much appreciated!
@CarlRI Welcome to the forums. I will gladly help you check your training details on the Fitbit app.
Open the app and scroll until you find the "exercise" tile. Tap on it and the list of the trainings will be shown. It displays the weekly activity. At the top you can change it for a monthly view so that more trainings are shown on the list. Tap on the desired training to go into the training summary. There you will find the details of that session. Hope this helps!
Best Answer01-10-2024 14:07
01-10-2024 14:07
@CarlRI Be advised that versions of the iOS app prior to 4.08 are extremely slow to show this data at times (I would see it take anywhere from 15 seconds to not showing it until I tried to edit and go back). I have seen v4.08 take 3-8 seconds to display the HR graph - definitely better, but you still have to be a little patient.
Not sure if the Android app suffers from this.
01-11-2024 08:00
01-11-2024 08:00
@mikey_pdx Thanks for the reply and your personal experience. I appreciate you sharing this, since I am an Android user and did not know about the loading time. I am glad to read this has improved with the last app update. Thanks again. Happy stepping!
Best Answer07-06-2024 15:01
07-06-2024 15:01
I have followed your instructions but I cannot find the heartrate graph that is currently available on the dashboard online. Could you please explain how we see the graph in the app?
Best Answer07-07-2024 11:45
07-07-2024 11:45
Hello @Apelam
It would be helpful if you could share a screenshot of what you see in the Fitbit app when you tap on the Exercise tile.
Are you using the Android or iOS Fitbit app?
Best Answer07-07-2024 13:50
07-07-2024 13:50
Best Answer07-08-2024 14:21
07-08-2024 14:21
Hi @Apelam
Thank you for letting us know that you are an iOS user.
Unfortunately, I'm not able to see your screenshot. Would you please be so kind as to try again?
Best Answer07-08-2024 14:59
07-08-2024 14:59
