Ever since Google took over log an exercise is really gone down hill. First they removed the web dashboard which was the only reliable way to do it. Form the phone app nothing works right:
1. you enter stuff and it changes your start time and duration after you enter it
2. you enter it on one device Android and doesn't show up on Apple and vise versa; further it prevents you from entering it on other device
3. you can't edit the end time for example for a GPS tracked walk or run in case you forgot to stop; only works if you delete the whole this and re-enter loosing GPS tracking data
4. the data entry is inconsistent between Android and Apple and neither is good; if you know duration you have to calculate then end time yourself and if you know end time you have to calculate duration yourself; stupid
Any plans to fix this horrible phone app?
