02-11-2025
02:44
10:51
AndreaFitbit
02-11-2025
02:44
10:51
AndreaFitbit
How can I find my charge6 tracker?Does GPS help me?
Moderator Edit: Formatting.
Best Answer02-11-2025 03:22
02-11-2025 03:22
Hello @Otto-Günter and welcome to the Community. Fitbits sync with Bluetooth and it has a working range of about 30 ft (10 m). If you can sync it, then it it in range and you need to keep looking. Fitbits are supposed to sync every fifteen minutes. You should be able to check the last sync time by tapping on your device/battery icon and checking that time on your Charge 6 tile. If you need to search a different area, where you think you lost it, try one of the Bluetooth find apps suggested in this Help article.
Laurie | Maryland
02-11-2025 03:22
02-11-2025 03:22
Laurie | Maryland
