07-11-2024 10:24
07-11-2024 10:24
I used to be able to manually add an exercise if I had not worn my Fitbit during that activity. I can no longer do that when I push the + Button I can only log sleep or weight. What is up?
Best Answer07-11-2024 11:41
07-11-2024 11:41
Hi @JJScottishGirl using Android, I'm able to log an activity. Maybe read this article on how to manually add to see if you can get it to work
Best Answer07-11-2024 15:03
07-11-2024 15:03
Hello @JJScottishGirl
Have you had a chance to try this:
Best Answer07-12-2024 06:39
07-12-2024 06:39
Best Answer07-12-2024 06:42
07-12-2024 06:42
Best Answer07-12-2024 13:47
07-12-2024 13:47
@JJScottishGirl what @RiekoC posted is the way I add a walk to my Fitbit. You have the latest app and a compatible phone? Those are the first things I'd check on. Read this - click
07-12-2024 14:44
07-12-2024 14:44
@JJScottishGirl Do you have your Exercise days tile on your added to your Today tiles? For example, if I remove my Exercise days, then it disappears when I tap on the plus symbol. Same is true for Food, Weight and Sleep.
Laurie | Maryland
08-09-2024 13:58
08-09-2024 13:58
Hi, I just had the same thing happen to me - no way to manually add exercise. I went to settings on my phone (I have an android) and allowed more permissions for fitbit. Then went back to the fitbit app, synced, and then i presses the plus. Viola, I had the choice for adding exercise! I dont know which permission did the trick, i think i just allowed everything, except it has to ask to use the microphone.
