08-24-2024 21:54
08-24-2024 21:54
How can I see all the activities I log at the gym in a gym session not just the latest. This change only showing the latest is new. A couple of months ago you could see them all under exercises, then it was changed to only show the latest but previous ones could be seen under activity. Now you can only see the latest. I typically use the elliptical and the treadmill and want to record and keep both.
Best Answer08-25-2024 14:46
08-25-2024 14:46
Hello @Franb1
As best as I can tell, completed workouts no longer are displayed under the Active Zone Minutes section.
To see your completed exercises, tap on the Exercise days tile. All your completed workouts will be there.
Best Answer08-24-2024 21:57
08-24-2024 21:57
Sorry I misspoke. The exercises all used to be shown under Activity, then only the latest but the others under Active Minutes. Now exercises no longer appear under Active minutes.
08-25-2024 14:46
08-25-2024 14:46
Hello @Franb1
Best Answer08-25-2024 17:43
08-25-2024 17:43
Thanks. I would never have thought to look there. Now I know.
07-21-2025 06:02
07-21-2025 06:02
New fitbit 6 owner. Called CS today for this issue. No one mentioned an EXERCISE DAYS tile. What is it and where is it? I accidentally discovered that if you delete the activity (last one showing in app) the previous one shows up, but never found a location to view all daily activity.
Best Answer07-21-2025 13:28
07-21-2025 13:28
Hello @GodsCardinal
The Exercise Days tile is on the Today page under the Activity section.
If you don't see the Exercise Days tile on your Today page, it might not be turned. This page (<-- click) has the instructions on how to edit your Today page. After you start the Edit mode, look in the Activity section for Exercise Days. If it's not turned on, tap on it to enable.
Please let us know if this helped.
Best Answer07-21-2025 15:17
07-21-2025 15:17
It's now under Cardio load
