11-05-2024 07:25
11-05-2024 07:25
My Charge 6 quit sequencing yesterday, 11/4/2024 and I have the iPhone. I reinstalled the latest update and am looking here for troubleshooting further. I’m a FitBit Premium member paying a yearly fee for nothing? What gives here!?
Best Answer11-05-2024 08:53
11-05-2024 08:53
Unfortunately it happens allllll the time. Mine currently won't sync either. Fitbit doesn't have an answer for it, along with most problems.
Best Answer11-05-2024 11:05
11-05-2024 11:05
Hello @lorado & @Leannek18
I've gotten confirmation that the team is aware some iOS users are experiencing syncing issues and are working on fixing the problem. Considering that the fix for the syncing issue that some Android users were experiencing was rolled out in an app update, I expect there will be a similar update for iOS users.
If I learn of any updates, I'll report back.
At this time, there isn't any troubleshooting that we can recommend since the issue is on the Fitbit side.
11-09-2024 06:20 - edited 11-09-2024 06:23
Hi there everyone! @lorado Welcome to the Fitbit Community! @Leannek18 It's great to see you here in the Community!
Thank you for informing us about this situation.
@RiekoC Thanks for the help! As you mentioned, our team is aware of the issue and they are working on finding a solution.
I'm sorry for all the inconveniences this has caused.
Can you please check which Fitbit app version you have?
Please check if you can update your phones too and try for the meantime to restart your phones and try to set up your devices again. For more information see: How do I set up my Fitbit device? and Why can't I set up my Fitbit device?
11-09-2024 07:02
11-09-2024 07:02
Android OS 10 - started having sync issues yesterday (11/08/2024) app version 4.28.3. Problems like this shouldn't be happening....
Best Answer11-09-2024 11:50
11-09-2024 11:50
Hello @JimC_99
There's a new Android update to version 4.29. I believe this update is supposed to include the fix for the Android users who still had syncing issues with version 4.28.3.
The updates tend to rollout in waves. Keep checking the Play Store for the update and install it when it's available.
Let us know if you're still having syncing problems after installing version 4.29.
