04-07-2024 05:58
04-07-2024 05:58
I've had my Charge 6 a few weeks now. It was fine until 8 days ago. It started only giving me basic sleep data (no REM, deep) and I also have no breathing rate or HRV data showing. I've uninstalled and reinstalled the app, I've done a hard reset. I've disconnected and reconnected bluetooth. I'm out of ideas. Any suggestions? Thanks!
04-10-2024 14:09
04-10-2024 14:09
Hello @Mel-Austin76
Do you see a green light on the back of your Charge 5? You can check by placing your finger across the back. You should see a green light when you lift your finger. That's the heart rate sensor.
If you're not seeing the green light, the first thing to check is that the Heart Rate setting didn't get turned off somehow:
If Heart Rate is turned on and you still don't see the green light, try turning the setting off, then back on. You might also want to try restarting your Charge 5 after turning the Heart Rate off, then back on. I've found that doing a restart often helps get my Fitbit "unstuck".
According to posts I've read, some users reported that doing a factory reset worked to re-enable the HR sensor. If this is what you meant when you said you did a hard reset in your post, you can ignore the following steps. I'll provide the steps in case it helps others.
Hopefully, you should see the green light on the back of the Charge 5 after the reset and the red light no longer shows. If you see the green light, then set up the Charge 5 in the Fitbit app as a new device. Although it's usually not necessary, I recommend deleting the previous Charge 5 from the app first.
If you didn't see the green light return after the factory reset, then it's likely your Charge 6 is defective. You should contact Fitbit support (<-- click link) to find out what are your options under warranty
