12-05-2023 02:13 - edited 12-05-2023 02:18
In the Android app under Devices connected to Fitbit it shows Charge 6 and Phone.
I have no problem syncing the Charge 6 but Phone shows synced '9 days ago'.
If the Charge 6 is syncing fine, and the web dashboard is up to date, what is the phone trying to sync to, and why isn't it?
Best Answer12-05-2023 12:20
12-05-2023 12:20
Hi @James1000
From your description, it looks like you have added your phone to use as a tracker (mainly steps) for times when you're not wearing your Charge 6. If you remove your phone as a device and start the process to add it back, you'll see the pages explaining how this feature works.
If you haven't used just your phone to track your steps, that will be why you don't see a recent sync with your phone. If you don't need this feature, it's fine to remove your phone as a Connected device.
Hope this clears up the confusion.
12-05-2023 12:20
12-05-2023 12:20
Hi @James1000
12-07-2023 01:51
12-07-2023 01:51
I may have without realising. Ive disconnected and reconnected the phone and now its syncing every so often.
Thanks for your help!
12-07-2023 11:15
12-07-2023 11:15
Hi @James1000
You're very welcome. Thanks for letting us know that it's working for you now.
03-19-2024 23:28
03-19-2024 23:28
My charge 6 needs to be synced to my phone every day as it loses connection. Is that normal?
Best Answer03-20-2024 02:13
03-20-2024 02:13
I dont why thats happening, but no its not normal. It should stay synced.
Best Answer03-20-2024 06:41
03-20-2024 06:41
Best Answer03-20-2024 11:21
03-20-2024 11:21
Hello @Pumpkin-123
By any chance, are you an iOS user? I've noticed iOS users have been reporting sync issues with their Fitbits and iPhones.
03-20-2024 11:26
03-20-2024 11:26
Best Answer03-21-2024 13:33
03-21-2024 13:33
Hello @Pumpkin-123
I'm pretty sure that the Fitbit team is aware of the issue and is working on resolving it. I only wish I knew what is the timeline to get this fixed.
03-21-2024 23:43
03-21-2024 23:43
Best Answer05-25-2024 06:16
05-25-2024 06:16
Hello, I have the same issue with my android app. Sense 2 shows syncing, but phone shows it was synced 190 days ago and I can't seem to find where to update this? My incoming calls and weather info doesn't work on my device sometimes but when I sync my app a few times it eventually starts to work. Not sure why on the app it shows my actual phone hasn't been synced since my initial set up? You mentioned that it's possible that the phone was only set up as a tracker? How would I know that before I disconnect the phone and start over?
Thank you in advance
Best Answer05-26-2024 15:18 - edited 05-26-2024 15:20
Hello @Sense2024
To see if you set up your phone as a tracker, tap on the device icon in the upper left of the Today page. This will open to the Connected to Fitbit page. Towards the bottom of the page, you will see Add connections. If you see Phone with the Add phone option, then your phone is not connected to the Fitbit app as a tracker.
If you see Phone under Devices, that means your phone was added as a tracker. To remove it, tap on Phone which will open to a new page. Tap on Disconnect device. A popup window will open. Tap on Disconnect. This will disconnect your phone as a tracker from the Fitbit app. But this will not affect the Fitbit app on your phone.
BTW, there's a sync icon at the top right of the page if your phone was added as a tracker. Tap on the sync icon and this will sync any steps tracked by your phone to the Fitbit app.
