Other post was moved to a forum about third party integration when the issue has nothing to do with integration of data from the apps.
Physical tracker, the charge 6, will no longer pair bua Bluetooth to share my hr rate on workout devices. This is an issue that came up after a firmware update pushed last week.
Running 66.20001.214.24 on tracker.
Best AnswerHi @Mikeiam I think you might get more help if you edit your title. Tap on the down arrow in the upper right of your post and use the Edit option. Try HR on Equipment not connecting.
I read the other post and understand why it got moved. There is more than one Peloton connection available. I don't use a Charge 6 and can't help you troubleshoot this issue.
Laurie | Maryland
