Question @ Fitbit | HR broadcast to bike computers
Hello,
Will the software of the Charge 6 be adjusted in the short term, so that the HR also works on bicycle computers such as the Garmin Edge? If not, I'll send it back.
1 REPLY 1
@Blieker if this feature is a "must have" then I suggest to send it back now. Knowing Fitbit you will not get answer to your question and most likely you'll fall out of your return window. Better return for full refund and buy again when (if) there is a fix 🤷 (I doubt Fitbit knows what bike computers are).
