09-23-2024 10:48 - edited 09-23-2024 10:50
I have worn my Fitbit charge 6 every night and for at least 14 hours a day And the readiness score says calibrating wear your Fitbit for seven more nights. Why am I not getting readiness score? This started about three days on my Fitbit charge five and has carried over to the new charge 6.
10-03-2024 17:20 - edited 10-04-2024 09:04
Hi everyone. I'm sorry to hear that your Readiness score says calibrating.
Please update your Fitbit app to the latest version in order to get it available (please be patient, it's been slowly rolling out, thank you).
Have a nice day!
09-23-2024 11:30
09-23-2024 11:30
Hello @Bam2448
The algorithm for the Daily Readiness score was changed with the recent app update. This help page explains how the readiness score is calculated as well as what changed (<-- click link).
Although the algorithm needs at least 7 nights of data to re-calibrate and re-calculate your readiness score, I've seen some users report that they finally saw their score before the 7th day. It sounds to me that the algorithm is still acquiring your data in order to calculate your score.
I've also seen some users report that they see their readiness score on their Fitbit device although it's not showing in the Fitbit app. So be sure to check both your device and the Fitbit app for your score.
09-23-2024 12:43 - edited 09-23-2024 12:43
Yes, actually I am seeing it on my charge 6 but not on the app. And the app breaks the readiness score down and I like to look at the three different areas that they’re evaluating. Hopefully it shows on my app sometime soon.
09-24-2024 05:55
09-24-2024 05:55
Thank you for the explanation!
09-25-2024 18:07
09-25-2024 18:07
I am having the same issue with my charge 6. I have worn continuously for more than 7 days and it still says wear 7 days
no readiness score🤷:female_sign:🤷:female_sign:🤦🏼:female_sign:🤦🏼:female_sign:
09-25-2024 20:00 - edited 10-03-2024 16:55
Me as well! Edit: it’s working now ty!!
09-26-2024 11:59
09-26-2024 11:59
Hello @clairebarb & @Roseydosey
It took awhile for my Readiness score to update and show the new score.
Since the algorithm uses a different set of data, it might take more time before it has the right amount of the necessary data. Be sure that you're wearing your device at night and you're getting sleep data.
10-02-2024 16:58
10-02-2024 16:58
I too am having the same issue. Seems like many are. Couldn't just be a coincidence 🙄
10-03-2024 12:41
10-03-2024 12:41
Hello @Shazzim , @Roseydosey , @clairebarb , @HoosierMama13 , @Bam2448
We are trying to find out why users aren't seeing their Readiness scores after wearing their Fitbits for 7+ days. I'll report back as soon as we have an update.
FWIW, I saw a Moderator post from yesterday (02 Oct 2024) stating that an app update will be rolling out in the next few days. Please keep checking the app store for the update.
10-03-2024 16:32
10-03-2024 16:32
Good Morning
Just letting you know that as of right now, my readiness score is now showing...for now.
Thank you
10-03-2024 16:54
Have a nice day!
10-04-2024 14:35
10-04-2024 14:35
Unfortunately I have gone back to not having it 😐
10-05-2024 01:50
10-05-2024 01:50
I had to wait 7 days for a score. You may not get a score if you’re not using tracker 24/7. I think it does require sleep data so if one night you’re not tracking sleep you may not get a score that day. I’m 25 today so green light todo Nothing 😂😂
04-26-2025 18:11
04-26-2025 18:11
What if my battery doesn't hold all 7 days to calibrate then I have ti charge it and start over and hope battery lasts? Seems redundant
04-30-2025 14:34 - edited 04-30-2025 14:35
Hello @cajohnson
The algorithm will use the data tracked by your Charge 6 for the Readiness score. It doesn't matter if you have to charge your battery in the meantime. At least, that's the way it worked for me.
If I misunderstood your question, please let us know.
