03-19-2025
09:53
07:32
DavidFitbit
03-19-2025
09:53
07:32
DavidFitbit
So I updated my Charge 6 this morning (on Android) now the repeating alarms are showing grey with a cross and the only way I can have them on is to have a 1 time alarm any ideas?
I've restarted the watch uninstalled the app on my phone and check DND and sleep mode and neither are on.
05-07-2025 05:41
05-07-2025 05:41
Why was this update pushed to me? It's been known to have issues for over a month! I need these alarms for work. Understand you affect people's livelihoods when pushing bad firmware to the public!
05-07-2025 05:48
05-07-2025 05:48
I did a test this morning and even though the repeating alarm was grey when I went to bed it still went off this morning at the correct time.
05-07-2025 14:16 - edited 05-07-2025 14:17
@DavidFitbit - It's now been two weeks since you said this issue had been escalated to a higher-level department and two months since initial reports that Fitbit broke our devices. What is the expected timeline for Fitbit to correct their error and restore functionality?
05-07-2025 14:58
05-07-2025 14:58
This issue has claimed another victim (me.)
Expect I am using an Inspire 3 -- I have updated, saw the problem, done a factory reset and now cannot re-setup.
05-07-2025 16:56
05-07-2025 16:56
For Inspire 3, factory reseting did seem to reset the update. I had trouble with re-setting up my device, and had to manually "Forget" the bluetooth device in my Android phone.
I cant speek for your device.
05-08-2025 21:05
05-08-2025 21:05
Same issue here. I don't know if I was more infuriated or relieved to find this thread. This does explain why I somehow slept past my alarm every day this week...but I can't believe this has been a known issue for this long and isn't resolved yet.
05-10-2025 04:32
05-10-2025 04:32
Thank you for sharing this! I was having the same problem, and your comment helped me know how to fix it.
05-10-2025 04:36 - edited 05-10-2025 04:40
🙋🏼 I've also been sad about this issue since the firmware update - but on my Inspire 3! 😒
05-12-2025 05:07 - edited 05-12-2025 05:13
how is this still broken?
I rely on this functionality, and it's a major reason why I purchased another Fitbit - I've been using Fitbit for years and just bought this Charge 6 to replace my Charge 5.
05-16-2025 10:56
05-16-2025 10:56
Having the same issue here in Ireland.
Friday
Friday
Same, very disappointing this issue was reported a almost 2 months, firmware was still pushed to my devices and another month later this still hasnt been resolved. Its an alarm application, seems like a pretty basic piece of SW
yesterday
yesterday
Can we get an update on this please? I have two affected inspire 3s and a brand new Charge 6 that I see the red dot for the update wanting to install for a few weeks now, and I refuse to install it. I need to adjust notification settings on my Charge but I can't because I have to do the update first. This is very inconvenient.
yesterday
yesterday
HEY GOOGLE!! YOU'RE SLEEPING??!? of course you are, your fitbit alarm must be broken too
7 hours ago
7 hours ago
Just adding another voice to this still being broken. Absolutely unbelievable that a dodgy firmware was pushed and hasn't been fixed. Having to set and reset alarms every day if you wake up at different times is insane. I have different wake up times depending on gym classes and work and have to set and reset everything daily because repeat alarms don't work.
When can we expect a fix?
an hour ago
an hour ago
There is talk that Google is phasing out Fitbit, if they don’t fix this, don’t buy a google watch to replace your Fitbit.
