11-18-2023
18:34
12:44
LizzyFitbit
11-18-2023
18:34
12:44
LizzyFitbit
After the latest update, I can no longer display distance and pace at the same time. Where the time is used to display the distance
while running. It used to show the distance on top and now shows the current time. I there a way to change this
11-30-2023 06:59
11-30-2023 06:59
Also looking to change this back to distance.
11-30-2023 07:55
11-30-2023 07:55
It’s very annoying. Any suggestions?
Best Answer11-30-2023 10:03
11-30-2023 10:03
Good catch. I have the same. Checked before and after the update. It needs to be reverted. Dist plus pace was perfect for me as well.
11-30-2023 11:18
11-30-2023 11:18
Looks like they changed it for other exercises, too. Weights used to have calories at the top.
Best Answer11-30-2023 13:57 - edited 12-01-2023 22:49
Moreover.. Distance has also expired from the default clock so I guess it
has to be a bug.
edit: regarding the default clock I've found a fix - just go to the charge 6/gallery on the app, then on the clock settings turn off the distance and turn it on again.
